Introduction
This guide will show you the steps required to replace the screen on your HP Envy x2 13-j002dx Detachable PC.
The display of this detachable PC also doubles as a touchscreen, so there may be more issues that appear unrelated to the display properties. The screen may need to be replaced if it begins to malfunction due to everyday wear, damage done by dropping the PC or objects hitting the screen. Apparent issues may include: unresponsiveness to tactile input, a cracked screen, black spots, and/or vertical lines along the entire screen. Issues not caused by physical damage may be resolved by updating the graphics driver.
Ce dont vous avez besoin
Remove five 4mm Phillips #0 screws securing the lower case to the HP Envy x2 13-j002dx.
Before removing the motherboard, clear away any dust, and ensure that the battery is already removed.
Once the battery and motherboard are removed, the screen unit should offer little resistance. Remove the screen from the base.
2 autres ont terminé cette réparation.
