Aller au contenu principal
HP Envy x360 15-bp143cl Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Envy x360 15-bp143cl Hard Drive Replacement, Hard Drive: étape 1, image 1 de 1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Hard Drive Replacement: étape 2, image 1 de 1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Hard Drive Replacement: étape 3, image 1 de 1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Hard Drive Replacement: étape 4, image 1 de 1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Hard Drive Replacement: étape 5, image 1 de 2 HP Envy x360 15-bp143cl Hard Drive Replacement: étape 5, image 2 de 2
    • Lift the black tab securing the hard drive connecting cable to the laptop to remove the cable.
  6. HP Envy x360 15-bp143cl Hard Drive Replacement: étape 6, image 1 de 1
    • Lift the hard drive from its slot.
    • If the hard drive is attached using adhesive, use an opening tool to pry it from the laptop.
Spencer Berkins
Membre depuis le 10/10/19
574 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S12-G3, Regan Fall 2019 Membre de l'équipe Cal Poly, Team S12-G3, Regan Fall 2019
CPSU-REGAN-F19S12G3
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 18
Total : 1,115
