Aller au contenu principal
HP Envy x360 15-bp143cl Touchpad Replacement
Ce dont vous avez besoin
  1. HP Envy x360 15-bp143cl Touchpad Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Touchpad Replacement: étape 2, image 1 de 1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Touchpad Replacement: étape 3, image 1 de 1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Touchpad Replacement: étape 4, image 1 de 1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Touchpad Replacement: étape 5, image 1 de 2 HP Envy x360 15-bp143cl Touchpad Replacement: étape 5, image 2 de 2
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl Touchpad Replacement: étape 6, image 1 de 1
    • Pull the battery from the connecting port and lift to remove it from the laptop.
  7. HP Envy x360 15-bp143cl Touchpad Replacement, Touchpad: étape 7, image 1 de 2 HP Envy x360 15-bp143cl Touchpad Replacement, Touchpad: étape 7, image 2 de 2
    • Use a spudger to peel the silver tape near the top right side of the touch pad.
  8. HP Envy x360 15-bp143cl Touchpad Replacement: étape 8, image 1 de 2 HP Envy x360 15-bp143cl Touchpad Replacement: étape 8, image 2 de 2
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 4mm screws securing the bottom metal bar.
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the three 1mm screws securing the top of the touch pad.
  9. HP Envy x360 15-bp143cl Touchpad Replacement: étape 9, image 1 de 1
    • Remove the metal cover by lifting it away from the laptop.
  10. HP Envy x360 15-bp143cl Touchpad Replacement: étape 10, image 1 de 2 HP Envy x360 15-bp143cl Touchpad Replacement: étape 10, image 2 de 2
    • Lift the bottom side of the touch pad.
    • Lift the black tab that secures the touch pad connecting cable to the laptop.
    • Pull the cable from the touch pad connecting port.
  11. HP Envy x360 15-bp143cl Touchpad Replacement: étape 11, image 1 de 2 HP Envy x360 15-bp143cl Touchpad Replacement: étape 11, image 2 de 2
    • Lift the touch pad to remove it.
Spencer Berkins
Membre depuis le 10/10/19
574 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S12-G3, Regan Fall 2019 Membre de l'équipe Cal Poly, Team S12-G3, Regan Fall 2019
CPSU-REGAN-F19S12G3
3 membres
6 tutoriels rédigés
Un commentaire
Thanks now have to find one on E-bay….or?
Michael - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 30
Total : 1,466
