Aller au contenu principal
HP Envy x360 15-u473cl Fan Replacement
Ce dont vous avez besoin
  1. HP Envy x360 15-u473cl Fan Replacement, Battery: étape 1, image 1 de 2 HP Envy x360 15-u473cl Fan Replacement, Battery: étape 1, image 2 de 2
    • Power off your laptop before beginning disassembly.
    • Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
    • Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
  2. HP Envy x360 15-u473cl Fan Replacement: étape 2, image 1 de 1
    • Remove the fourteen 7mm screws using the Phillips #0 screwdriver from the bottom of the laptop.
  3. HP Envy x360 15-u473cl Fan Replacement: étape 3, image 1 de 2 HP Envy x360 15-u473cl Fan Replacement: étape 3, image 2 de 2
    • Turn the device right side up and open the lid.
    • Insert the plastic opening tool in between the keyboard plate and the base of laptop.
    • Run the tool along seem, prying up as you go.
    • Separate the keyboard plate from the base, lifting from the front.
  4. HP Envy x360 15-u473cl Fan Replacement: étape 4, image 1 de 1
    • There are 3 ribbon cables (black, white, and copper color) connecting the computer to the keyboard plate. Disconnect the 3 ribbon cables using the plastic opening tool by prying up the latches holding each cable in place.
    • Remove the keyboard plate from the device.
  5. HP Envy x360 15-u473cl Fan Replacement: étape 5, image 1 de 1
    • Remove the thick white ribbon cable covering the battery using the plastic opening tool by prying up the latches attaching each end.
  6. HP Envy x360 15-u473cl Fan Replacement: étape 6, image 1 de 1
    • Remove the three 4mm screws using the Phillips #0 screwdriver.
  7. HP Envy x360 15-u473cl Fan Replacement: étape 7, image 1 de 1
    • Disconnect the battery from the motherboard.
    • There may be tamper-proof tape holding the battery in place. Remove the tape if present.
    • Remove the battery from the device.
  8. HP Envy x360 15-u473cl Fan Replacement, Fan: étape 8, image 1 de 1
    • Remove the three 4mm screws using the Phillips #0 screwdriver from the device fan.
  9. HP Envy x360 15-u473cl Fan Replacement: étape 9, image 1 de 2 HP Envy x360 15-u473cl Fan Replacement: étape 9, image 2 de 2
    • Disconnect the fan from the motherboard using the spudger.
    • Remove the fan from the device.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 25
Total : 1,462
