Aller au contenu principal
HP Envy x360 15-u473cl RAM Replacement
Ce dont vous avez besoin
  1. HP Envy x360 15-u473cl RAM  Replacement, Battery: étape 1, image 1 de 2 HP Envy x360 15-u473cl RAM  Replacement, Battery: étape 1, image 2 de 2
    • Power off your laptop before beginning disassembly.
    • Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
    • Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
  2. HP Envy x360 15-u473cl RAM  Replacement: étape 2, image 1 de 1
    • Remove the fourteen 7mm screws using the Phillips #0 screwdriver from the bottom of the laptop.
  3. HP Envy x360 15-u473cl RAM  Replacement: étape 3, image 1 de 2 HP Envy x360 15-u473cl RAM  Replacement: étape 3, image 2 de 2
    • Turn the device right side up and open the lid.
    • Insert the plastic opening tool in between the keyboard plate and the base of laptop.
    • Run the tool along seem, prying up as you go.
    • Separate the keyboard plate from the base, lifting from the front.
  4. HP Envy x360 15-u473cl RAM  Replacement: étape 4, image 1 de 1
    • There are 3 ribbon cables (black, white, and copper color) connecting the computer to the keyboard plate. Disconnect the 3 ribbon cables using the plastic opening tool by prying up the latches holding each cable in place.
    • Remove the keyboard plate from the device.
  5. HP Envy x360 15-u473cl RAM  Replacement: étape 5, image 1 de 1
    • Remove the thick white ribbon cable covering the battery using the plastic opening tool by prying up the latches attaching each end.
  6. HP Envy x360 15-u473cl RAM  Replacement: étape 6, image 1 de 1
    • Remove the three 4mm screws using the Phillips #0 screwdriver.
  7. HP Envy x360 15-u473cl RAM  Replacement: étape 7, image 1 de 1
    • Disconnect the battery from the motherboard.
    • There may be tamper-proof tape holding the battery in place. Remove the tape if present.
    • Remove the battery from the device.
  8. HP Envy x360 15-u473cl RAM  Replacement, Fan: étape 8, image 1 de 1
    • Remove the three 4mm screws using the Phillips #0 screwdriver from the device fan.
  9. HP Envy x360 15-u473cl RAM  Replacement: étape 9, image 1 de 2 HP Envy x360 15-u473cl RAM  Replacement: étape 9, image 2 de 2
    • Disconnect the fan from the motherboard using the spudger.
    • Remove the fan from the device.
  10. HP Envy x360 15-u473cl RAM  Replacement, Motherboard: étape 10, image 1 de 2 HP Envy x360 15-u473cl RAM  Replacement, Motherboard: étape 10, image 2 de 2
    • Remove the five 4mm screws with the Phillips #0 screwdriver.
    • Remove one 3mm screw with the Phillips #00 screwdriver.
  11. HP Envy x360 15-u473cl RAM  Replacement: étape 11, image 1 de 2 HP Envy x360 15-u473cl RAM  Replacement: étape 11, image 2 de 2
    • Disconnect the 2 white ribbon cables using the plastic opening tool.
    • Disconnect the two black cable bundles using the plastic opening tool.
  12. HP Envy x360 15-u473cl RAM  Replacement: étape 12, image 1 de 3 HP Envy x360 15-u473cl RAM  Replacement: étape 12, image 2 de 3 HP Envy x360 15-u473cl RAM  Replacement: étape 12, image 3 de 3
    • Disconnect the charging port wire bundle from the motherboard using the plastic opening tool.
    • Disconnect the wireless card by pulling away from the black transistor using the spudger.
    • Remove the motherboard.
  13. HP Envy x360 15-u473cl RAM  Replacement, RAM: étape 13, image 1 de 3 HP Envy x360 15-u473cl RAM  Replacement, RAM: étape 13, image 2 de 3 HP Envy x360 15-u473cl RAM  Replacement, RAM: étape 13, image 3 de 3
    • Use both fingers to push the tabs to the side and release the RAM.
    • Remove the RAM chip by pulling away from the connector.
    • Repeat the procedure for the second RAM chip.
Matthew Ortman
Membre depuis le 11/07/19
163 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S3-G3, Harley Fall 2019 Membre de l'équipe IUPUI, Team S3-G3, Harley Fall 2019
IUPUI-HARLEY-F19S3G3
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 811
