Aller au contenu principal
HP Envy x360 15m-bp111dx Battery Replacement
Ce dont vous avez besoin
  1. HP Envy x360 15m-bp111dx Battery Replacement, Back Panel: étape 1, image 1 de 2 HP Envy x360 15m-bp111dx Battery Replacement, Back Panel: étape 1, image 2 de 2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Battery Replacement: étape 2, image 1 de 3 HP Envy x360 15m-bp111dx Battery Replacement: étape 2, image 2 de 3 HP Envy x360 15m-bp111dx Battery Replacement: étape 2, image 3 de 3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Battery Replacement, Battery: étape 3, image 1 de 2 HP Envy x360 15m-bp111dx Battery Replacement, Battery: étape 3, image 2 de 2
    • Use a Phillips screwdriver to remove the seven 4 mm screws securing the battery.
  4. HP Envy x360 15m-bp111dx Battery Replacement: étape 4, image 1 de 3 HP Envy x360 15m-bp111dx Battery Replacement: étape 4, image 2 de 3 HP Envy x360 15m-bp111dx Battery Replacement: étape 4, image 3 de 3
    • Carefully lift the battery, and pull it towards you to remove it.
Tori Luongo
Membre depuis le 02/22/22
250 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 2-2, Hunter Spring 2022 Membre de l'équipe Clemson, Team 2-2, Hunter Spring 2022
CLEM-HUNTER-S22S2G2
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 13
Total : 351
