Aller au contenu principal
HP Envy x360 15m-bp112dx Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Envy x360 15m-bp112dx Hard Drive Replacement, Hard Drive: étape 1, image 1 de 1
    • Power off the laptop before starting the disassembly.
    • Start by facing the device upside down with the hinge facing away from you.
    • Remove the seven 1 mm Phillips screws.
  2. HP Envy x360 15m-bp112dx Hard Drive Replacement: étape 2, image 1 de 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: étape 2, image 2 de 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: étape 2, image 3 de 3
    • Use an opening tool to pry the back panel by pushing the bottom cover upwards.
    • Place the bottom cover away from the laptop.
  3. HP Envy x360 15m-bp112dx Hard Drive Replacement: étape 3, image 1 de 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: étape 3, image 2 de 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: étape 3, image 3 de 3
    • Carefully remove the sata ribbon cable from the hard drive, pulling it out horizontally.
    • To avoid injury, ensure that you disconnect the battery prior to removing any of the cables in the laptop.
  4. HP Envy x360 15m-bp112dx Hard Drive Replacement: étape 4, image 1 de 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: étape 4, image 2 de 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: étape 4, image 3 de 3
    • Remove the hard drive by pulling it out vertically.
    • Remove the plastic casing around the hard drive by peeling it back.
  5. HP Envy x360 15m-bp112dx Hard Drive Replacement: étape 5, image 1 de 2 HP Envy x360 15m-bp112dx Hard Drive Replacement: étape 5, image 2 de 2
    • Disconnect the ribbon cable by pulling it away horizontally from the hard drive.
Mohamed Kozamel
Membre depuis le 03/20/23
121 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 6-2, Botvin Spring 2023 Membre de l'équipe UMass Dartmouth, Team 6-2, Botvin Spring 2023
UMASSD-BOTVIN-S23S6G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 19
Total : 260
