Aller au contenu principal
HP Envy x360 15m-bp112dx Screen Assembly Replacement
Ce dont vous avez besoin
  1. HP Envy x360 15m-bp112dx Screen Assembly Replacement, Hard Drive: étape 1, image 1 de 1
    • Power off the laptop before starting the disassembly.
    • Start by facing the device upside down with the hinge facing away from you.
    • Remove the seven 1 mm Phillips screws.
  2. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 2, image 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 2, image 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 2, image 3 de 3
    • Use an opening tool to pry the back panel by pushing the bottom cover upwards.
    • Place the bottom cover away from the laptop.
  3. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 3, image 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 3, image 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 3, image 3 de 3
    • Carefully remove the sata ribbon cable from the hard drive, pulling it out horizontally.
    • To avoid injury, ensure that you disconnect the battery prior to removing any of the cables in the laptop.
  4. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 4, image 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 4, image 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 4, image 3 de 3
    • Remove the hard drive by pulling it out vertically.
    • Remove the plastic casing around the hard drive by peeling it back.
  5. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 5, image 1 de 2 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 5, image 2 de 2
    • Disconnect the ribbon cable by pulling it away horizontally from the hard drive.
  6. HP Envy x360 15m-bp112dx Screen Assembly Replacement, Fan: étape 6, image 1 de 2 HP Envy x360 15m-bp112dx Screen Assembly Replacement, Fan: étape 6, image 2 de 2
    • Carefully peel back the tape connecting the heat sink to the fan assembly.
    • Loosen the four 1 mm Phillips screws retaining the fan assembly.
    • Remove the three 2 mm Phillips screws.
  7. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 7, image 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 7, image 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 7, image 3 de 3
    • Unplug the thin cable connected to the fan, pulling horizontally.
    • Carefully peel back the connected tape.
  8. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 8, image 1 de 2 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 8, image 2 de 2
    • Carefully remove the fan assembly by pulling on it upwards.
    • When reassembling, ensure that you clean off and replace the thermal paste on the fan assembly.
  9. HP Envy x360 15m-bp112dx Screen Assembly Replacement, Motherboard: étape 9, image 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement, Motherboard: étape 9, image 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement, Motherboard: étape 9, image 3 de 3
    • Remove the two 5 mm Phillips screws from the first speaker.
    • Carefully peel back the tape.
  10. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 10, image 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 10, image 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 10, image 3 de 3
    • Open the tab connected to the right speaker cord, prying it with a plastic opening tool upwards.
    • Pull out the speaker cord horizontally.
  11. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 11, image 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 11, image 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 11, image 3 de 3
    • Remove the thin cable from the speaker, pulling it out horizontally.
  12. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 12, image 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 12, image 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 12, image 3 de 3
    • Remove the right speaker, pulling upward carefully.
    • While pulling on the speaker, unwind the cord around the plastic clips to free the speaker and place it to the side.
  13. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 13, image 1 de 1
    • Remove the twelve 2.5 mm Phillips screws.
  14. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 14, image 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 14, image 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 14, image 3 de 3
    • Unclip the ribbon cable using a plastic opening tool to flip up the black ZIF connector locking flap.
    • Remove the ribbon cable by pulling it out horizontally.
  15. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 15, image 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 15, image 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 15, image 3 de 3
    • Unclip the second ribbon cable using a plastic opening tool to flip the black ZIF connector locking flap up.
  16. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 16, image 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 16, image 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 16, image 3 de 3
    • Unclip the third ribbon cable using a plastic opening tool to flip up the black ZIF connector locking flap.
  17. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 17, image 1 de 2 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 17, image 2 de 2
    • Remove the thin cable carefully by pulling out horizontally in line with its slot.
  18. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 18, image 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 18, image 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 18, image 3 de 3
    • Unclip the fourth ribbon cable using a plastic opening tool to flip up the black ZIF connector.
  19. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 19, image 1 de 2 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 19, image 2 de 2
    • Carefully remove the motherboard by pulling upwards on it.
  20. HP Envy x360 15m-bp112dx Screen Assembly Replacement, Speakers: étape 20, image 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement, Speakers: étape 20, image 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement, Speakers: étape 20, image 3 de 3
    • The removal of the right speaker is located in the motherboard guide during steps 1-4.
    • Remove the two 1.5 mm Phillips screws.
    • Carefully peel the tape back.
    • Pull the left speaker cord around the plastic clips.
  21. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 21, image 1 de 2 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 21, image 2 de 2
    • Carefully remove the left speaker by pulling up vertically.
  22. HP Envy x360 15m-bp112dx Screen Assembly Replacement, Screen Assembly: étape 22, image 1 de 2 HP Envy x360 15m-bp112dx Screen Assembly Replacement, Screen Assembly: étape 22, image 2 de 2
    • Remove the four 5 mm Phillips screws.
    • Remove the one 5 mm Phillips screw.
    • Carefully remove the Wi-Fi card, lifting upwards.
  23. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 23, image 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 23, image 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 23, image 3 de 3
    • Disconnect the wires from the Wi-Fi card by using an opening tool and pulling the wires upwards.
  24. HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 24, image 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 24, image 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: étape 24, image 3 de 3
    • Unscrew the four 5 mm Phillips screws.
    • Separate the screen from the rest of the laptop by opening the laptop like a book and pushing the two parts away from each other.
James Bonnell
Membre depuis le 03/20/23
331 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-2, Botvin Spring 2023 Membre de l'équipe UMass Dartmouth, Team 6-2, Botvin Spring 2023
UMASSD-BOTVIN-S23S6G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 37
Total : 361
