Introduction
When displays get old they may have groups of pixels that die or have all of them die making it impossible to see anything. Replace the display using our guide.
Ce dont vous avez besoin
On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan as shown in this picture.
Using a Phillips #1, remove the seven M2.0x3.2 screws.
Undo the six connections using the blue opening tool.
Use the tweezers to remove the cords from their restraints.
Lift the speakers out of the laptop.
Remove the three 4.4 mm screws from each hinge using a Phillips #0 screwdriver.
