Aller au contenu principal
HP Envy x360 15m-bq021dx Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Envy x360 15m-bq021dx Hard Drive Replacement, Battery: étape 1, image 1 de 2 HP Envy x360 15m-bq021dx Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx Hard Drive Replacement: étape 2, image 1 de 3 HP Envy x360 15m-bq021dx Hard Drive Replacement: étape 2, image 2 de 3 HP Envy x360 15m-bq021dx Hard Drive Replacement: étape 2, image 3 de 3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx Hard Drive Replacement: étape 3, image 1 de 1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx Hard Drive Replacement: étape 4, image 1 de 1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx Hard Drive Replacement: étape 5, image 1 de 1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx Hard Drive Replacement, Hard Drive: étape 6, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Use the tweezers to lift up the retaining flap on the cable connector.
    • Pull out the ribbon cable from the connector.
  7. HP Envy x360 15m-bq021dx Hard Drive Replacement: étape 7, image 1 de 1
    • Use the spudger to lift the hard drive from the cutout.
Un commentaire
Followed guide to remove HDD from 15m-bq121dx model. Steps were identical. Took more force than I expected to remove bottom cover and to get the HDD out.
Adam Francis - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 16
Total : 673
