Aller au contenu principal
HP Envy x360 15m-bq021dx Keyboard Replacement
Ce dont vous avez besoin
  1. HP Envy x360 15m-bq021dx Keyboard Replacement, Battery: étape 1, image 1 de 2 HP Envy x360 15m-bq021dx Keyboard Replacement, Battery: étape 1, image 2 de 2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx Keyboard Replacement: étape 2, image 1 de 3 HP Envy x360 15m-bq021dx Keyboard Replacement: étape 2, image 2 de 3 HP Envy x360 15m-bq021dx Keyboard Replacement: étape 2, image 3 de 3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx Keyboard Replacement: étape 3, image 1 de 1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx Keyboard Replacement: étape 4, image 1 de 1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx Keyboard Replacement: étape 5, image 1 de 1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx Keyboard Replacement, Cooling Fan: étape 6, image 1 de 2 HP Envy x360 15m-bq021dx Keyboard Replacement, Cooling Fan: étape 6, image 2 de 2
    • Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan as shown in this picture.
    • Be careful as the fan might be sharp in some places when removing it.
  7. HP Envy x360 15m-bq021dx Keyboard Replacement: étape 7, image 1 de 2 HP Envy x360 15m-bq021dx Keyboard Replacement: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    • Remove the connector clip with the tweezers.
  8. HP Envy x360 15m-bq021dx Keyboard Replacement: étape 8, image 1 de 1
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  9. HP Envy x360 15m-bq021dx Keyboard Replacement: étape 9, image 1 de 2 HP Envy x360 15m-bq021dx Keyboard Replacement: étape 9, image 2 de 2
    • Remove the cooling fan.
  10. HP Envy x360 15m-bq021dx Keyboard Replacement, Motherboard: étape 10, image 1 de 3 HP Envy x360 15m-bq021dx Keyboard Replacement, Motherboard: étape 10, image 2 de 3 HP Envy x360 15m-bq021dx Keyboard Replacement, Motherboard: étape 10, image 3 de 3
    • Using a Phillips #1, remove the seven M2.0x3.2 screws.
    • Undo the six connections using the blue opening tool.
  11. HP Envy x360 15m-bq021dx Keyboard Replacement: étape 11, image 1 de 3 HP Envy x360 15m-bq021dx Keyboard Replacement: étape 11, image 2 de 3 HP Envy x360 15m-bq021dx Keyboard Replacement: étape 11, image 3 de 3
    • Carefully remove the aux port from the frame of the computer as shown.
  12. HP Envy x360 15m-bq021dx Keyboard Replacement: étape 12, image 1 de 2 HP Envy x360 15m-bq021dx Keyboard Replacement: étape 12, image 2 de 2
    • Pull the mother board up and away from frame of the computer.
  13. HP Envy x360 15m-bq021dx Keyboard Replacement, Speakers: étape 13, image 1 de 1
    • Use the tweezers to remove the cords from their restraints.
    • Lift the speakers out of the laptop.
  14. HP Envy x360 15m-bq021dx Keyboard Replacement, Keyboard: étape 14, image 1 de 3 HP Envy x360 15m-bq021dx Keyboard Replacement, Keyboard: étape 14, image 2 de 3 HP Envy x360 15m-bq021dx Keyboard Replacement, Keyboard: étape 14, image 3 de 3
    • Use flat cutters or an iFixit Opening Tool to cut the excess plastic off the plastic pins holding the keyboard backing plate.
    • Make sure just to remove the excess plastic because to reinstall the backing plate the pins must be melted back around the backing plate.
    • When reassembling move back to the last step now (Step 21).
  15. HP Envy x360 15m-bq021dx Keyboard Replacement: étape 15, image 1 de 3 HP Envy x360 15m-bq021dx Keyboard Replacement: étape 15, image 2 de 3 HP Envy x360 15m-bq021dx Keyboard Replacement: étape 15, image 3 de 3
    • Remove the two M2.0x3.2 screws using a Phillips #0 screwdriver holding the bracket.
    • Lift the upper bracket off.
    • Remove the three M3.0x3.2 screws using the Phillips #0 screwdriver securing the touchpad.
  16. HP Envy x360 15m-bq021dx Keyboard Replacement: étape 16, image 1 de 3 HP Envy x360 15m-bq021dx Keyboard Replacement: étape 16, image 2 de 3 HP Envy x360 15m-bq021dx Keyboard Replacement: étape 16, image 3 de 3
    • Use an iFixit opening tool to lift the locking flap and pull the ribbon cable out.
    • Lift the touch pad out of the frame.
    • When reassembling use tweezers to hold and insert the ribbon cable. Also, the middle flange of the touchpad goes above the flange on the plate.
  17. HP Envy x360 15m-bq021dx Keyboard Replacement: étape 17, image 1 de 3 HP Envy x360 15m-bq021dx Keyboard Replacement: étape 17, image 2 de 3 HP Envy x360 15m-bq021dx Keyboard Replacement: étape 17, image 3 de 3
    • Using a Phillips #0 screwdriver, remove the three screws on both hinges.
    • Pry the hinges back so they are not blocking the keyboard backing plate.
    • If the case comes off the hinges slide the case back to the hinges and push the case in place.
  18. HP Envy x360 15m-bq021dx Keyboard Replacement: étape 18, image 1 de 2 HP Envy x360 15m-bq021dx Keyboard Replacement: étape 18, image 2 de 2
    • Pull the keyboard backing plate off of the laptop but be aware that it is connected to a ribbon cable still.
    • It might take some force to pry the plate from the pins.
    • Pull the keyboard ribbon cable off the backing plate and through it.
    • When reassembling, make sure the side with the black markings is facing up.
  19. HP Envy x360 15m-bq021dx Keyboard Replacement: étape 19, image 1 de 2 HP Envy x360 15m-bq021dx Keyboard Replacement: étape 19, image 2 de 2
    • Pull the keyboard off of the case.
  20. HP Envy x360 15m-bq021dx Keyboard Replacement: étape 20, image 1 de 3 HP Envy x360 15m-bq021dx Keyboard Replacement: étape 20, image 2 de 3 HP Envy x360 15m-bq021dx Keyboard Replacement: étape 20, image 3 de 3
    • To reassemble follow the previous steps in reverse until reaching step 15.
    • Instead of completing step 15 complete the following step.
    • Using a soldering iron and melt the plastic pins so the plastic holds the backing plate down.
    • Make sure the plate is pressed down firmly as the pins are melted so that the plate is held tightly by the pins.
To reassemble your device, follow the instructions from step 14 to step 1 in reverse order.
2 autres ont terminé cette réparation.
1Commentaire sur le guide
WOW, great instructions. I ran the HP hardware test and confirmed that the keyboard is bad. For forty dollars, I think I'll just buy a Logitech wireless keyboard. Although, your instructions give me the confidence to perform this repair if neccessary. Thank you.
Reggie Hall - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 17
30 derniers jours : 105
Total : 5,192
