Introduction
In the event that your HP Envy x360 15m-bq021dx laptop is not charging, replace the power input connector. Before using this guide make sure to power off your device completely.
Ce dont vous avez besoin
On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan as shown in this picture.
Using a Phillips #1, remove the seven M2.0x3.2 screws.
Undo the six connections using the blue opening tool.
Use the tweezers to remove the cords from their restraints.
Lift the speakers out of the laptop.
Remove the three M2.0x3.2 hinge screws next to the power input cord using a Philips #0 screwdriver.
Pry the hinge up so that it is out of the way.
