Aller au contenu principal
HP Envy x360 15m-bq021dx RAM Replacement
Ce dont vous avez besoin
  1. HP Envy x360 15m-bq021dx RAM Replacement, Battery: étape 1, image 1 de 2 HP Envy x360 15m-bq021dx RAM Replacement, Battery: étape 1, image 2 de 2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx RAM Replacement: étape 2, image 1 de 3 HP Envy x360 15m-bq021dx RAM Replacement: étape 2, image 2 de 3 HP Envy x360 15m-bq021dx RAM Replacement: étape 2, image 3 de 3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx RAM Replacement: étape 3, image 1 de 1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx RAM Replacement: étape 4, image 1 de 1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx RAM Replacement: étape 5, image 1 de 1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx RAM Replacement, RAM: étape 6, image 1 de 1
    • Remove the tape near the RAM storage.
  7. HP Envy x360 15m-bq021dx RAM Replacement: étape 7, image 1 de 2 HP Envy x360 15m-bq021dx RAM Replacement: étape 7, image 2 de 2
    • Use a small blue opening tool to pry open the protective metal cover.
  8. HP Envy x360 15m-bq021dx RAM Replacement: étape 8, image 1 de 1
    • Pull on the silver pins away from the RAM on both sides.
  9. HP Envy x360 15m-bq021dx RAM Replacement: étape 9, image 1 de 2 HP Envy x360 15m-bq021dx RAM Replacement: étape 9, image 2 de 2
    • Pull the RAM up and out to remove.
Hunter Reihart
Membre depuis le 09/04/19
506 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 26
Total : 1,692
