Aller au contenu principal
HP Envy x360 15m-bq021dx Touchpad Replacement
Ce dont vous avez besoin
  1. HP Envy x360 15m-bq021dx Touchpad Replacement, Battery: étape 1, image 1 de 2 HP Envy x360 15m-bq021dx Touchpad Replacement, Battery: étape 1, image 2 de 2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx Touchpad Replacement: étape 2, image 1 de 3 HP Envy x360 15m-bq021dx Touchpad Replacement: étape 2, image 2 de 3 HP Envy x360 15m-bq021dx Touchpad Replacement: étape 2, image 3 de 3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx Touchpad Replacement: étape 3, image 1 de 1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx Touchpad Replacement: étape 4, image 1 de 1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx Touchpad Replacement: étape 5, image 1 de 1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx Touchpad Replacement, Touchpad: étape 6, image 1 de 2 HP Envy x360 15m-bq021dx Touchpad Replacement, Touchpad: étape 6, image 2 de 2
    • Remove the three (3) 2.0x3.4 mm screws using a Phillips #0 screwdriver.
  7. HP Envy x360 15m-bq021dx Touchpad Replacement: étape 7, image 1 de 3 HP Envy x360 15m-bq021dx Touchpad Replacement: étape 7, image 2 de 3 HP Envy x360 15m-bq021dx Touchpad Replacement: étape 7, image 3 de 3
    • Use the blue opening tool to detach the purple tab on white strip from the black electrical insert.
    • Pull the white strip up and out of the black insert.
  8. HP Envy x360 15m-bq021dx Touchpad Replacement: étape 8, image 1 de 1
    • Use the blue opening tool to lift the screw tab in order to grasp the touch pad instrument.
  9. HP Envy x360 15m-bq021dx Touchpad Replacement: étape 9, image 1 de 3 HP Envy x360 15m-bq021dx Touchpad Replacement: étape 9, image 2 de 3 HP Envy x360 15m-bq021dx Touchpad Replacement: étape 9, image 3 de 3
    • In one motion, gently lift and slide the touch pad instrument out of its original place.
Samuel Kirkland
Membre depuis le 09/04/19
186 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 620
