Aller au contenu principal
HP Envy x360 15m-bq121dx Cooling Fan Replacement
Ce dont vous avez besoin
  1. HP Envy x360 15m-bq121dx Cooling Fan Replacement, Cooling Fan: étape 1, image 1 de 2 HP Envy x360 15m-bq121dx Cooling Fan Replacement, Cooling Fan: étape 1, image 2 de 2
    • Be sure the computer is powered off.
    • Remove the rubber strip along the top of the backside of the computer.
    • On the back panel of the device, remove the four (4) 2.5 mm screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq121dx Cooling Fan Replacement: étape 2, image 1 de 3 HP Envy x360 15m-bq121dx Cooling Fan Replacement: étape 2, image 2 de 3 HP Envy x360 15m-bq121dx Cooling Fan Replacement: étape 2, image 3 de 3
    • To remove the back cover, use the spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
    • Be sure to not damage any of the electronics on the inside.
  3. HP Envy x360 15m-bq121dx Cooling Fan Replacement: étape 3, image 1 de 1
    • Use the Philips #0 screwdriver to remove seven 2 mm screws from battery.
  4. HP Envy x360 15m-bq121dx Cooling Fan Replacement: étape 4, image 1 de 1
    • Lift and pull the front of the battery up and out away from the connector to remove.
  5. HP Envy x360 15m-bq121dx Cooling Fan Replacement: étape 5, image 1 de 2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: étape 5, image 2 de 2
    • Using a Philips #0 screwdriver, remove the three 2 mm screws located around the cooling fan as shown in this picture.
    • The fan may have sharp edges so be careful upon removal.
  6. HP Envy x360 15m-bq121dx Cooling Fan Replacement: étape 6, image 1 de 2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Remove the connector clip with the tweezers.
  7. HP Envy x360 15m-bq121dx Cooling Fan Replacement: étape 7, image 1 de 1
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  8. HP Envy x360 15m-bq121dx Cooling Fan Replacement: étape 8, image 1 de 2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: étape 8, image 2 de 2
    • Remove the cooling fan.
Fabien Perez
Membre depuis le 02/13/20
157 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 37
Total : 1,889
