Aller au contenu principal
HP Envy x360 15m-cn0012dx Daughterboard Replacement
Ce dont vous avez besoin
  1. HP Envy x360 15m-cn0012dx Daughterboard Replacement, Daughterboard: étape 1, image 1 de 2 HP Envy x360 15m-cn0012dx Daughterboard Replacement, Daughterboard: étape 1, image 2 de 2
    • Make sure the computer is turned off, and remove all cables.
    • Set the laptop face down.
    • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
    • Peel slowly to avoid tearing the rubber covers.
  2. HP Envy x360 15m-cn0012dx Daughterboard Replacement: étape 2, image 1 de 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: étape 2, image 2 de 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: étape 2, image 3 de 3
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
  3. HP Envy x360 15m-cn0012dx Daughterboard Replacement: étape 3, image 1 de 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: étape 3, image 2 de 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: étape 3, image 3 de 3
    • Pry open the back cover using the iFixit Opening Tool.
    • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
    • Once all the corners are slightly lifted, carefully pop off the back cover.
  4. HP Envy x360 15m-cn0012dx Daughterboard Replacement: étape 4, image 1 de 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: étape 4, image 2 de 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: étape 4, image 3 de 3
    • Use the iFixit opening tool to unlatch the ZIF connector with the cable labelled 'SD' from the daughterboard.
    • Slide out the interconnect ribbon cable.
  5. HP Envy x360 15m-cn0012dx Daughterboard Replacement: étape 5, image 1 de 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: étape 5, image 2 de 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: étape 5, image 3 de 3
    • Using a Phillips #0 screwdriver, remove the two 4mm screws on holding down the SD card daughterboard.
    • Remove the SD card daughterboard.
Grace Daleki
Membre depuis le 02/04/20
475 Réputation
3 tutoriels rédigés
Équipe
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 Membre de l'équipe UW Stout, Team S1-G3, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 15
Total : 711
