Aller au contenu principal
HP Envy x360 m6-aq103dx Battery Replacement
Ce dont vous avez besoin
  1. HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: étape 1, image 1 de 3 HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: étape 1, image 2 de 3 HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: étape 1, image 3 de 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Battery Replacement: étape 2, image 1 de 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Battery Replacement: étape 3, image 1 de 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Battery Replacement: étape 4, image 1 de 3 HP Envy x360 m6-aq103dx Battery Replacement: étape 4, image 2 de 3 HP Envy x360 m6-aq103dx Battery Replacement: étape 4, image 3 de 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx Battery Replacement, Battery: étape 5, image 1 de 2 HP Envy x360 m6-aq103dx Battery Replacement, Battery: étape 5, image 2 de 2
    • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
  6. HP Envy x360 m6-aq103dx Battery Replacement: étape 6, image 1 de 3 HP Envy x360 m6-aq103dx Battery Replacement: étape 6, image 2 de 3 HP Envy x360 m6-aq103dx Battery Replacement: étape 6, image 3 de 3
    • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
    • Lift up the port with the tool.
  7. HP Envy x360 m6-aq103dx Battery Replacement: étape 7, image 1 de 3 HP Envy x360 m6-aq103dx Battery Replacement: étape 7, image 2 de 3 HP Envy x360 m6-aq103dx Battery Replacement: étape 7, image 3 de 3
    • Lift the battery out of the laptop with your hands.
5 autres ont terminé cette réparation.
Sarah Samora
Membre depuis le 10/02/17
777 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S4-G3, Livingston Fall 2017 Membre de l'équipe Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 28
Total : 7,391
