Introduction
Is your HP Envy x360 m6-aq103dx not holding a charge like it used to? If so, here is the guide to fix this problem by simply changing the battery. All you need is a #1 Phillips Screwdriver, a T5 Torx screwdriver heads, the nylon black spudger, and the plastic opening tool in order to remove the five types of screws involved with this replacement.
Ce dont vous avez besoin
Flip the laptop over to expose the underside.
Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
5 autres ont terminé cette réparation.
