Aller au contenu principal
HP Envy x360 m6-aq103dx CPU Fan Replacement
Ce dont vous avez besoin
  1. HP Envy x360 m6-aq103dx CPU Fan Replacement, Bottom Cover: étape 1, image 1 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement, Bottom Cover: étape 1, image 2 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement, Bottom Cover: étape 1, image 3 de 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 2, image 1 de 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 3, image 1 de 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 4, image 1 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 4, image 2 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 4, image 3 de 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx CPU Fan Replacement, CPU Fan: étape 5, image 1 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement, CPU Fan: étape 5, image 2 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement, CPU Fan: étape 5, image 3 de 3
    • Put on the anti-static wristband first
    • Disconnect the port of the fan by flipping the black tab with the small blue plastic opening tool.
    • Remove the cable from the connector.
  6. HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 6, image 1 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 6, image 2 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 6, image 3 de 3
    • Peel back a little bit of the grey tape connected to the round cable with the big blue opening tool.
    • Using your fingers, peel the tape off of the body of the computer.
    • Peel slowly to avoid separating the adhesive.
  7. HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 7, image 1 de 2 HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 7, image 2 de 2
    • Remove the black cable from the fan by unclicking it from the plastic body of the fan with your fingers and move it out of the area.
    • There will be clicking sounds when the black cable is removed.
  8. HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 8, image 1 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 8, image 2 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 8, image 3 de 3
    • Disconnect the port with the red yellow and blue wires by dislodging the wires with your fingers.
  9. HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 9, image 1 de 1
    • Remove the two 4.5mm Phillips #1 screws.
  10. HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 10, image 1 de 1
    • Loosen the four black screws by the curved heat sink with a Phillips head 1 screwdriver.
    • These screws do not come off.
  11. HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 11, image 1 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 11, image 2 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement: étape 11, image 3 de 3
    • Lift the CPU fan out with your hand.
4 autres ont terminé cette réparation.
Jordan Eremeyeff
Membre depuis le 10/01/17
597 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S4-G3, Livingston Fall 2017 Membre de l'équipe Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 membres
9 tutoriels rédigés
3 commentaires
Step 5-7 can be bypassed I didn’t need to do it
diego.montenegro23 - Réponse
My first home repair so far. Really easy to follow guide. Great job!
Caleb Robinson - Réponse
Purchased tools and did the steps, no issues. worth the tools to use later. Worked in iT anyways.
Roy Rodgers - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 10
Total : 4,456
