Aller au contenu principal
HP Envy x360 m6-aq103dx Display Replacement
Ce dont vous avez besoin
  1. HP Envy x360 m6-aq103dx Display Replacement, Bottom Cover: étape 1, image 1 de 3 HP Envy x360 m6-aq103dx Display Replacement, Bottom Cover: étape 1, image 2 de 3 HP Envy x360 m6-aq103dx Display Replacement, Bottom Cover: étape 1, image 3 de 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Display Replacement: étape 2, image 1 de 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Display Replacement: étape 3, image 1 de 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Display Replacement: étape 4, image 1 de 3 HP Envy x360 m6-aq103dx Display Replacement: étape 4, image 2 de 3 HP Envy x360 m6-aq103dx Display Replacement: étape 4, image 3 de 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx Display Replacement, Battery: étape 5, image 1 de 2 HP Envy x360 m6-aq103dx Display Replacement, Battery: étape 5, image 2 de 2
    • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
  6. HP Envy x360 m6-aq103dx Display Replacement: étape 6, image 1 de 3 HP Envy x360 m6-aq103dx Display Replacement: étape 6, image 2 de 3 HP Envy x360 m6-aq103dx Display Replacement: étape 6, image 3 de 3
    • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
    • Lift up the port with the tool.
  7. HP Envy x360 m6-aq103dx Display Replacement: étape 7, image 1 de 3 HP Envy x360 m6-aq103dx Display Replacement: étape 7, image 2 de 3 HP Envy x360 m6-aq103dx Display Replacement: étape 7, image 3 de 3
    • Lift the battery out of the laptop with your hands.
  8. HP Envy x360 m6-aq103dx Display Replacement, Display: étape 8, image 1 de 2 HP Envy x360 m6-aq103dx Display Replacement, Display: étape 8, image 2 de 2
    • Click the back cover on so none of the internal components are damaged during the following steps.
    • Open the display, so it is flat and the screen is facing up.
    • Put the suction cup in the middle of the screen.
  9. HP Envy x360 m6-aq103dx Display Replacement: étape 9, image 1 de 2 HP Envy x360 m6-aq103dx Display Replacement: étape 9, image 2 de 2
    • Wedge the small plastic opening tool between the frame and the screen and pry it open by lifting up.
  10. HP Envy x360 m6-aq103dx Display Replacement: étape 10, image 1 de 2 HP Envy x360 m6-aq103dx Display Replacement: étape 10, image 2 de 2
    • Slide the tool around the edge of the frame while pulling on the suction cup.
    • Popping sounds are ok.
  11. HP Envy x360 m6-aq103dx Display Replacement: étape 11, image 1 de 1
    • Take the suction cup off before laying the screen on the keyboard.
  12. HP Envy x360 m6-aq103dx Display Replacement: étape 12, image 1 de 3 HP Envy x360 m6-aq103dx Display Replacement: étape 12, image 2 de 3 HP Envy x360 m6-aq103dx Display Replacement: étape 12, image 3 de 3
    • Remove the grey tape covering the wires by pulling on the tab slowly (located at the bottom of the display.
    • Detach the grey tape and the clear tape by wedging the small blue opening tool under the tape enough to raise a corner and pull the tape off with your hand.
    • Remove the tape slowly to avoid separating the adhesive.
    • Do this for both pieces of tape that cover wires.
  13. HP Envy x360 m6-aq103dx Display Replacement: étape 13, image 1 de 3 HP Envy x360 m6-aq103dx Display Replacement: étape 13, image 2 de 3 HP Envy x360 m6-aq103dx Display Replacement: étape 13, image 3 de 3
    • For the round cable underneath the smaller of the two pieces of tape, remove the cable by sliding it backwards.
    • Remove the other cable by pulling on the tape downwards and backwards.
  14. HP Envy x360 m6-aq103dx Display Replacement: étape 14, image 1 de 3 HP Envy x360 m6-aq103dx Display Replacement: étape 14, image 2 de 3 HP Envy x360 m6-aq103dx Display Replacement: étape 14, image 3 de 3
    • Lift the screen up with your hands.
12 autres ont terminé cette réparation.
Christopher Martinez
Membre depuis le 10/02/17
430 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S4-G3, Livingston Fall 2017 Membre de l'équipe Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 membres
9 tutoriels rédigés
8 commentaires
Thank you for this. I was getting REAL nervous as I got to the bottom portion of the screen. It really looks like the bottom is a separate panel (with screws under it) - Your photos assured me that it was not, so I gave it a little more and she came right off. Excellent work and photos!
[Only edit would be, no need to take the battery out, just disconnect]
Kyle B - Réponse
Where can I get the screen to buy online please, I am from Africa
aholylier - Réponse
Amazon or Ebay work. Just be sure your getting a screen with the proper resolution. You can inspect the connector to see what one you have if you dont know (the pin configuration is slightly diferent)
Kyle B - Réponse
which resolution requires what pins
Chris Henrie -
do you know the part number of the display for this laptop?
Debbie Endara - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 85
Total : 14,232
