Aller au contenu principal
HP Envy x360 m6-aq105dx Audio Jack Replacement
Ce dont vous avez besoin
  1. HP Envy x360 m6-aq105dx Audio Jack Replacement, Back Cover: étape 1, image 1 de 1
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx Audio Jack Replacement: étape 2, image 1 de 1
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
  3. HP Envy x360 m6-aq105dx Audio Jack Replacement, Audio Jack: étape 3, image 1 de 1
    • Attach the grounding bracelet's clip to the frame of the laptop, then put on the grounding bracelet.
    • Remove the two 4.6 mm screws using the Phillips #0 screwdriver.
    • Remove the one 4.4mm screw using the Phillips #0 screwdriver.
    • Remove the one 2.8mm screws securing the audio jack/power button board using the Phillips #0 screwdriver.
  4. HP Envy x360 m6-aq105dx Audio Jack Replacement: étape 4, image 1 de 2 HP Envy x360 m6-aq105dx Audio Jack Replacement: étape 4, image 2 de 2
    • Place the blue plastic opening tool on top of the blue data ribbon and under the connector. Lift up on the blue plastic opening tool to open the connector.
    • Remove the blue data ribbon from the audio board.
  5. HP Envy x360 m6-aq105dx Audio Jack Replacement: étape 5, image 1 de 2 HP Envy x360 m6-aq105dx Audio Jack Replacement: étape 5, image 2 de 2
    • Remove the audio jack motherboard from the computer.
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 354
