Aller au contenu principal
HP Envy x360 m6-w105dx Battery Replacement
Ce dont vous avez besoin
  1. HP Envy x360 m6-w105dx Battery Replacement, Keyboard: étape 1, image 1 de 3 HP Envy x360 m6-w105dx Battery Replacement, Keyboard: étape 1, image 2 de 3 HP Envy x360 m6-w105dx Battery Replacement, Keyboard: étape 1, image 3 de 3
    • Make sure the laptop is powered off and disconnected from any outlets.
    • Use the opening pick to lift up the eight rubber grips on the underside of the device.
    • With the #1 Phillips screwdriver, remove the twelve 6mm screws from the back case.
  2. HP Envy x360 m6-w105dx Battery Replacement: étape 2, image 1 de 2 HP Envy x360 m6-w105dx Battery Replacement: étape 2, image 2 de 2
    • Open the laptop and turn to the keyboard.
    • Gently insert an opening pick into the edge of the keyboard panel, and slide around the keyboard lining until the clips have all been disengaged.
    • Lift the keyboard panel from the bottom and carefully start to lift up.
    • There are ribbon cables still connected on the under side of the the keyboard. Do not pull the keyboard away from the device.
  3. HP Envy x360 m6-w105dx Battery Replacement: étape 3, image 1 de 2 HP Envy x360 m6-w105dx Battery Replacement: étape 3, image 2 de 2
    • Gently lift the keyboard up from the bottom.
    • Carefully open the locking flap of the three ZIF connectors and detach the three ribbon cables from the motherboard using your fingers.
    • Do not remove the ZIF connectors by pulling on the wires, instead detach them by gently flipping up the plastic tabs located at the ends of the wiring.
    • Fully remove the keyboard from the laptop and install your new keyboard.
  4. HP Envy x360 m6-w105dx Battery Replacement, Battery: étape 4, image 1 de 2 HP Envy x360 m6-w105dx Battery Replacement, Battery: étape 4, image 2 de 2
    • Carefully flip up the locking tabs on the ZIF connectors and remove the ribbon cables from the connectors.
    • Disconnect the battery cable by sliding it downward from the connector with an iFixit opening tool.
    • Using this tool reduces the chance of any sparking or electronic charge.
  5. HP Envy x360 m6-w105dx Battery Replacement: étape 5, image 1 de 2 HP Envy x360 m6-w105dx Battery Replacement: étape 5, image 2 de 2
    • Using the Phillips #1 screwdriver, unscrew the four 6 mm screws.
  6. HP Envy x360 m6-w105dx Battery Replacement: étape 6, image 1 de 2 HP Envy x360 m6-w105dx Battery Replacement: étape 6, image 2 de 2
    • Gently lift the battery up from the case and replace it.
3 autres ont terminé cette réparation.
youbin
Membre depuis le 01/26/20
115 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 29
Total : 1,811
