Aller au contenu principal
HP Flyer Red Keyboard Replacement
Ce dont vous avez besoin
  1. HP Flyer Red Keyboard Replacement, Battery: étape 1, image 1 de 2 HP Flyer Red Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Make sure your laptop is powered off.
    • With laptop closed flip to look at the underside of the laptop.
  2. HP Flyer Red Keyboard Replacement: étape 2, image 1 de 1
    • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
  3. HP Flyer Red Keyboard Replacement: étape 3, image 1 de 2 HP Flyer Red Keyboard Replacement: étape 3, image 2 de 2
    • The left switch is the battery unlock switch.
    • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
  4. HP Flyer Red Keyboard Replacement: étape 4, image 1 de 1
    • Then take and slide the other switch to the other end of its track which will pop out the battery.
    • Grab the battery and pull it out of the slot.
  5. HP Flyer Red Keyboard Replacement, Keyboard: étape 5, image 1 de 2 HP Flyer Red Keyboard Replacement, Keyboard: étape 5, image 2 de 2
    • Next locate and unscrew the two 4mm Phllips #1 screws with the keyboard symbol located towards the middle and top of the bottom of the laptop.
  6. HP Flyer Red Keyboard Replacement: étape 6, image 1 de 3 HP Flyer Red Keyboard Replacement: étape 6, image 2 de 3 HP Flyer Red Keyboard Replacement: étape 6, image 3 de 3
    • Next turn the laptop over and flip open the screen.
    • Use the plastic opening tool to pry the keyboard upwards from the bottom right hand corner of the keyboard.
    • Use another plastic opening tool with the first plastic opening tool you placed to undo every plastic clasp surrounding the keyboard.
  7. HP Flyer Red Keyboard Replacement: étape 7, image 1 de 3 HP Flyer Red Keyboard Replacement: étape 7, image 2 de 3 HP Flyer Red Keyboard Replacement: étape 7, image 3 de 3
    • Next lift up the keyboard gently and use the plastic opening tool to undo the ribbon wire by unclasping the ZIF (zero insertion force) connector to the laptop.
    • Gently slide the ribbon wire out of its slot.
7 autres ont terminé cette réparation.
Anthony Ciotti
Membre depuis le 04/07/16
747 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-5, Catania Spring 2016 Membre de l'équipe UMass Dartmouth, Team 4-5, Catania Spring 2016
UMASSD-CATANIA-S16S4G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 11
Total : 2,219
