Aller au contenu principal
HP Folio 13t-1000 Battery Replacement
Ce dont vous avez besoin
  1. HP Folio 13t-1000 Battery Replacement, Keyboard: étape 1, image 1 de 2 HP Folio 13t-1000 Battery Replacement, Keyboard: étape 1, image 2 de 2
    • Use an antistatic wrist wrap, or periodically touch unpainted metal to minimize the risk of damaging the laptop by electrostatic shock.
    • Use a PH1 screw head to remove the 16, 6mm screws from the bottom case housing of the laptop.
  2. HP Folio 13t-1000 Battery Replacement: étape 2, image 1 de 3 HP Folio 13t-1000 Battery Replacement: étape 2, image 2 de 3 HP Folio 13t-1000 Battery Replacement: étape 2, image 3 de 3
    • This step requires unlocking the very fragile plastic clips along the frame; take care not to damage them.
    • Slide the spudger with a twisting motion along the entire perimeter of the laptop until the top cover is separated from the frame of the device.
  3. HP Folio 13t-1000 Battery Replacement: étape 3, image 1 de 1
    • Using the flat portion of the plastic spudger, push the corner of the black surface until the first clip unlocks.
    • The top right corner of the keyboard should now be sticking out slightly.
    • Repeat the same process for the top left corner.
  4. HP Folio 13t-1000 Battery Replacement: étape 4, image 1 de 2 HP Folio 13t-1000 Battery Replacement: étape 4, image 2 de 2
    • Slide the keyboard up and towards the screen just enough to separate the keyboard from the top cover.
  5. HP Folio 13t-1000 Battery Replacement: étape 5, image 1 de 3 HP Folio 13t-1000 Battery Replacement: étape 5, image 2 de 3 HP Folio 13t-1000 Battery Replacement: étape 5, image 3 de 3
    • To unlock the clamps connected to the motherboard, use your fingers or insert the pointed edge of the spudger between the first clamp and the cable.
    • Repeat the same process for the second clamp.
  6. HP Folio 13t-1000 Battery Replacement: étape 6, image 1 de 3 HP Folio 13t-1000 Battery Replacement: étape 6, image 2 de 3 HP Folio 13t-1000 Battery Replacement: étape 6, image 3 de 3
    • Remove the keyboard from the laptop.
  7. HP Folio 13t-1000 Battery Replacement, Top Hardware Cover: étape 7, image 1 de 3 HP Folio 13t-1000 Battery Replacement, Top Hardware Cover: étape 7, image 2 de 3 HP Folio 13t-1000 Battery Replacement, Top Hardware Cover: étape 7, image 3 de 3
    • Place your finger between one of the plastic clamps and the cable and apply a slight leveraging force until the clamp pops up.
    • Do the same for the second connection.
  8. HP Folio 13t-1000 Battery Replacement: étape 8, image 1 de 2 HP Folio 13t-1000 Battery Replacement: étape 8, image 2 de 2
    • Remove the top hardware cover.
  9. HP Folio 13t-1000 Battery Replacement, Battery: étape 9, image 1 de 2 HP Folio 13t-1000 Battery Replacement, Battery: étape 9, image 2 de 2
    • Use a PH1 screw head to remove the two, 3mm screws.
  10. HP Folio 13t-1000 Battery Replacement: étape 10, image 1 de 1
    • Remove the motherboard connection using the nylon spudger or your fingers.
  11. HP Folio 13t-1000 Battery Replacement: étape 11, image 1 de 1
    • Separate the ribbon from the battery by wedging the flat metal spudger between the two.
  12. HP Folio 13t-1000 Battery Replacement: étape 12, image 1 de 2 HP Folio 13t-1000 Battery Replacement: étape 12, image 2 de 2
    • Remove old battery and replace with a new one.
Cody Badchkam
Membre depuis le 09/28/16
64 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 1-2, Cagle Fall 2016 Membre de l'équipe USF Tampa, Team 1-2, Cagle Fall 2016
USFT-CAGLE-F16S1G2
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 591
