Introduction
Make sure you have completed the keyboard replacement guide and the top cover removal guide.
A defective RAM can cause your laptop's loading speed to deteriorate. This guide will show you how to correctly replace a defective or an outdated RAM for your HP Folio 13t-1000.
Ce dont vous avez besoin
Use a PH1 screw head to remove the 16, 6mm screws from the bottom case housing of the laptop.
Place your finger between one of the plastic clamps and the cable and apply a slight leveraging force until the clamp pops up.
Do the same for the second connection.
Using the tips of your fingers, gently apply opposite outward force until the two clips are no longer holding the RAM stick.
