Aller au contenu principal
HP G60T-600 CTO RAM Replacement
Ce dont vous avez besoin
  1. HP G60T-600 CTO RAM Replacement, Battery: étape 1, image 1 de 1
    • Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Close your device, then turn it over.
  2. HP G60T-600 CTO RAM Replacement: étape 2, image 1 de 2 HP G60T-600 CTO RAM Replacement: étape 2, image 2 de 2
    • Place your index finger on the ridged tab.
  3. HP G60T-600 CTO RAM Replacement: étape 3, image 1 de 1
    • Apply moderate pressure to the tab and slide it to the right.
    • While the tab is on the right, you should be able to gently slide your battery out of your device.
  4. HP G60T-600 CTO RAM Replacement, RAM: étape 4, image 1 de 1
    • Turn your device over and orient it so the battery is facing you.
  5. HP G60T-600 CTO RAM Replacement: étape 5, image 1 de 3 HP G60T-600 CTO RAM Replacement: étape 5, image 2 de 3 HP G60T-600 CTO RAM Replacement: étape 5, image 3 de 3
    • Unscrew the following 5mm screws using a Phillips head #0 screwdriver.
    • Remove the cover.
  6. HP G60T-600 CTO RAM Replacement: étape 6, image 1 de 3 HP G60T-600 CTO RAM Replacement: étape 6, image 2 de 3 HP G60T-600 CTO RAM Replacement: étape 6, image 3 de 3
    • Place your fingers on little metals tabs on both sides of the RAM casing.
    • Push the tabs towards the sides. This should cause the RAM to pop up.
  7. HP G60T-600 CTO RAM Replacement: étape 7, image 1 de 1
    • Pull on it with medium force at the angle it is oriented.
Dominic DeSantis
Membre depuis le 10/19/16
772 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-5, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 4-5, Catania Fall 2016
UMASSD-CATANIA-F16S4G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 158
