Aller au contenu principal
HP G62 347NR CD/DVD Drive Replacement
Ce dont vous avez besoin
  1. HP G62 347NR  CD/DVD Drive Replacement, CD/DVD Drive: étape 1, image 1 de 1
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR  CD/DVD Drive Replacement: étape 2, image 1 de 1
    • Remove the battery, carefully, from the compartment.
  3. HP G62 347NR  CD/DVD Drive Replacement: étape 3, image 1 de 1
    • Find the hard drive compartment with two Phillips head screws.
    • Use the PH1 screwdriver to loosen and remove both screws.
    • Gently remove the hard drive compartment.
  4. HP G62 347NR  CD/DVD Drive Replacement: étape 4, image 1 de 1
    • On the far left of the hard drive compartment, find the Phillips head screw.
    • Remove the Phillips head screw with the PH1 screwdriver.
  5. HP G62 347NR  CD/DVD Drive Replacement: étape 5, image 1 de 2 HP G62 347NR  CD/DVD Drive Replacement: étape 5, image 2 de 2
    • Get the plastic opening tool and place it between the laptop and the CD/DVD drive. Place it toward the center of the drive for maximum support.
    • Carefully pry the CD/DVD drive open.
    • Slide the CD/DVD drive out once it is pried open.
McKenzi Morris
Membre depuis le 10/10/16
511 Réputation
3 tutoriels rédigés
Équipe
Texas Tech, Team 6-1, Bennett Fall 2016 Membre de l'équipe Texas Tech, Team 6-1, Bennett Fall 2016
TTU-BENNETT-F16S6G1
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 12
Total : 590
