Aller au contenu principal
HP G62-144DX Keyboard Replacement
Ce dont vous avez besoin
  1. HP G62-144DX Keyboard Replacement, Battery: étape 1, image 1 de 2 HP G62-144DX Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX Keyboard Replacement, Keyboard: étape 2, image 1 de 1
    • Remove the 3 Phillips 2.5x5 screws (closest to the battery slot) and the 2 Phillips 2.5x6.5 screws with a Phillips #1 screwdriver.
    • This screws will have a keyboard symbol inscribed next to them.
  3. HP G62-144DX Keyboard Replacement: étape 3, image 1 de 3 HP G62-144DX Keyboard Replacement: étape 3, image 2 de 3 HP G62-144DX Keyboard Replacement: étape 3, image 3 de 3
    • Use the Phillips # 1 screwdriver to unscrew the 2.5x6 Phillips screws holding the L-shaped back panel.
    • Screws should stay in panel, but come free of the laptop body.
    • Gently use a plastic opening tool to remove the panel.
  4. HP G62-144DX Keyboard Replacement: étape 4, image 1 de 2 HP G62-144DX Keyboard Replacement: étape 4, image 2 de 2
    • Unscrew the final Phillips 2.5x5 keyboard screw with a Phillips #1 screwdriver.
  5. HP G62-144DX Keyboard Replacement: étape 5, image 1 de 2 HP G62-144DX Keyboard Replacement: étape 5, image 2 de 2
    • Flip the laptop so the top is facing up again and open the cover.
    • Use a metal spudger to pry the keyboard up and pull it back.
    • Be sure to pry up the board itself and not an individual key.
    • This process has the risk of breaking keys.
  6. HP G62-144DX Keyboard Replacement: étape 6, image 1 de 2 HP G62-144DX Keyboard Replacement: étape 6, image 2 de 2
    • Pull up the latch that connects the keyboard connector the the motherboard.
2 autres ont terminé cette réparation.
Cameron Moran
Membre depuis le 10/18/17
623 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G8, Julie Fall 2017 Membre de l'équipe UMass Dartmouth, Team S4-G8, Julie Fall 2017
UMASSD-JULIE-F17S4G8
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 619
