Aller au contenu principal
HP G62-144DX RAM Replacement
Ce dont vous avez besoin
  1. HP G62-144DX RAM Replacement, Battery: étape 1, image 1 de 2 HP G62-144DX RAM Replacement, Battery: étape 1, image 2 de 2
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX RAM Replacement, RAM: étape 2, image 1 de 3 HP G62-144DX RAM Replacement, RAM: étape 2, image 2 de 3 HP G62-144DX RAM Replacement, RAM: étape 2, image 3 de 3
    • Unscrew the three Phillips 2.5x6 screws in the L-shaped panel on the back with a Phillips #1 screwdriver.
    • The screws will stay in the panel, but will come loose from the body of the laptop.
    • Use a plastic opening tool to gently pry the panel free from the laptop.
  3. HP G62-144DX RAM Replacement: étape 3, image 1 de 3 HP G62-144DX RAM Replacement: étape 3, image 2 de 3 HP G62-144DX RAM Replacement: étape 3, image 3 de 3
    • Pull the two metal clips to the top RAM module outwards parallel to the laptop.
    • After the RAM module pops up, gently pull in out from the computer.
    • Repeat for the second RAM module.
Cameron Moran
Membre depuis le 10/18/17
623 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G8, Julie Fall 2017 Membre de l'équipe UMass Dartmouth, Team S4-G8, Julie Fall 2017
UMASSD-JULIE-F17S4G8
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 345
