Aller au contenu principal
HP G62-223CL Optical Drive Replacement
Ce dont vous avez besoin
  1. HP G62-223CL Optical Drive Replacement, Battery Removal: étape 1, image 1 de 2 HP G62-223CL Optical Drive Replacement, Battery Removal: étape 1, image 2 de 2
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
  2. HP G62-223CL Optical Drive Replacement: étape 2, image 1 de 1
    • Carefully remove the battery from its compartment.
  3. HP G62-223CL Optical Drive Replacement, Optical Drive: étape 3, image 1 de 1
    • Locate two Phillips head retaining screws which secure the hard drive compartment.
    • Use a Phillips #0 screwdriver to loosen the retaining screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
  4. HP G62-223CL Optical Drive Replacement: étape 4, image 1 de 1
    • Locate the 6 mm Phillips head screw to the left of the hard drive.
    • Use a Phillips #0 screwdriver to remove the screw.
  5. HP G62-223CL Optical Drive Replacement: étape 5, image 1 de 2 HP G62-223CL Optical Drive Replacement: étape 5, image 2 de 2
    • Once the screw is removed, use a plastic opening tool and place it between the body of the computer and the optical drive.
    • Apply enough pressure to loosen the optical drive.
    • The optical drive can then be removed by hand.
Garret Layton
Membre depuis le 01/13/15
669 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Sullivan Winter 2015 Membre de l'équipe USF Tampa, Team 1-4, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 10
Total : 1,239
