Aller au contenu principal
HP G71t-400 WiFi Card Replacement
Ce dont vous avez besoin
  1. HP G71t-400 WiFi Card Replacement, WiFi Card: étape 1, image 1 de 3 HP G71t-400 WiFi Card Replacement, WiFi Card: étape 1, image 2 de 3 HP G71t-400 WiFi Card Replacement, WiFi Card: étape 1, image 3 de 3
    • Lay the laptop down so the bottom is facing up.
    • Push the slide button, circled in photo 1, to release the battery.
    • Action in picture 2 shows the direction and release.
    • Tilt the battery back in the direction it popped up in and remove the battery.
    • This ensures there is no power in the system that could potentially short out any components.
  2. HP G71t-400 WiFi Card Replacement: étape 2, image 1 de 3 HP G71t-400 WiFi Card Replacement: étape 2, image 2 de 3 HP G71t-400 WiFi Card Replacement: étape 2, image 3 de 3
    • Remove the only circled screw.
    • Lift and remove the cover exposing the WiFi card.
  3. HP G71t-400 WiFi Card Replacement: étape 3, image 1 de 1
    • Disconnect the two wires attached. Making note to where each wire was connected for easy install.
    • Extract the WiFi card.
Nicholas Castro
Membre depuis le 03/24/19
711 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G5, Simcock Spring 2019 Membre de l'équipe UMass Dartmouth, Team S1-G5, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G5
2 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 89
