Aller au contenu principal
HP G72 Optical Drive Replacement
Ce dont vous avez besoin
  1. HP G72 Optical Drive Replacement, Optical Drive: étape 1, image 1 de 3 HP G72 Optical Drive Replacement, Optical Drive: étape 1, image 2 de 3 HP G72 Optical Drive Replacement, Optical Drive: étape 1, image 3 de 3
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer.
    • Turn the computer so that it faces upside down. Position the computer with the front toward you.
    • Slide the battery release latch to release the battery. Pivot the battery to remove it.
  2. HP G72 Optical Drive Replacement: étape 2, image 1 de 3 HP G72 Optical Drive Replacement: étape 2, image 2 de 3 HP G72 Optical Drive Replacement: étape 2, image 3 de 3
    • Remove the Phillips M2.5x5.0 screw that is identified by the optical disk icon.
    • Pull the optical drive out of its slot.
    • Remove the drive from the computer.
oldturkey03
Membre depuis le 09/29/10
782 169 Réputation
119 tutoriels rédigés
Équipe
Global Fixers Membre de l'équipe Global Fixers
Community
33 membres
537 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 1,457
