Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
  1. Pull on the two tabs on the back of the printer to release the left side cover. Remove the cover by rotating it towards the front of the printer. Remove the cover by rotating it towards the front of the printer.
    • Pull on the two tabs on the back of the printer to release the left side cover.
    • Remove the cover by rotating it towards the front of the printer.
  2. With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place. Lift the cover off of the printer. Lift the cover off of the printer.
    • With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place.
    • Lift the cover off of the printer.
  3. SAUTEZ LA MISE À NIVEAU
    Économisez en réparant avec un kit tout-en-un.
    Fix Kits pour iPhone
  4. Remove 4 screws on the back of the printer. Remove the back cover. Remove the back cover.
    • Remove 4 screws on the back of the printer.
    • Remove the back cover.
  5. Remove 2 screws on the back of the printer, one on the left, and one on the front. The second image shows the formatter removed, but it is not necessary to remove the formatter to replace the top cover. The second image shows the formatter removed, but it is not necessary to remove the formatter to replace the top cover.
    • Remove 2 screws on the back of the printer, one on the left, and one on the front.
    • The second image shows the formatter removed, but it is not necessary to remove the formatter to replace the top cover.
  6. Disconnect the control panel cable and remove the top cover.
    • Disconnect the control panel cable and remove the top cover.
  7. Remove one cable from the top of the laser assembly and one cable from the right side of the laser assembly. Remove 4 screws from the laser assembly. Remove all cables from the cable clip on the side of the laser assembly and remove it from the printer.
    • Remove one cable from the top of the laser assembly and one cable from the right side of the laser assembly.
    • Remove 4 screws from the laser assembly.
    • Remove all cables from the cable clip on the side of the laser assembly and remove it from the printer.
jdp23
Membre depuis le 22/08/2013
1 275 Réputation
23 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 294
