Aller au contenu principal
HP Media Center 876x Front Cover Replacement
Ce dont vous avez besoin
  1. HP Media Center 876x Front Cover Replacement, Side Panel: étape 1, image 1 de 2 HP Media Center 876x Front Cover Replacement, Side Panel: étape 1, image 2 de 2
    • Remove the two (9 mm) hand screws on the back panel.
  2. HP Media Center 876x Front Cover Replacement: étape 2, image 1 de 3 HP Media Center 876x Front Cover Replacement: étape 2, image 2 de 3 HP Media Center 876x Front Cover Replacement: étape 2, image 3 de 3
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. HP Media Center 876x Front Cover Replacement, Front Cover: étape 3, image 1 de 2 HP Media Center 876x Front Cover Replacement, Front Cover: étape 3, image 2 de 2
    • Orient the tower vertically.
    • Using the #0 Phillips head screwdriver, unscrew and remove the two (5 mm) screws that fasten the remaining side panel to the tower.
    • Slide the side panel out of its notches, and pull it gently off of the tower.
  4. HP Media Center 876x Front Cover Replacement: étape 4, image 1 de 1
    • Gently move the tower so that it is in the horizontal orientation.
    • Press down the black tabs (proximal to you) that fasten the front panel to the tower.
    • Press down on the distal, black tabs (symmetric with respect to the previous tabs).
    • Pull front panel forward slightly.
  5. HP Media Center 876x Front Cover Replacement: étape 5, image 1 de 2 HP Media Center 876x Front Cover Replacement: étape 5, image 2 de 2
    • The front panel will come off in a hinge-like fashion, exposing the drives underneath.
Balakrishnan Pillai
Membre depuis le 03/26/14
1 003 Réputation
8 tutoriels rédigés
Équipe
Clemson, Team 6-1, Benson Spring 2014 Membre de l'équipe Clemson, Team 6-1, Benson Spring 2014
CLEM-BENSON-S14S6G1
3 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 449
