Introduction
Use this guide to replace the hard drive.
Outils
Pièces
With the case closed, place the Mini 1000 top-side down on a flat surface.
Push both of the battery release latches toward each other.
Remove the following two screws:
One 6 mm Phillips screw
One 4 mm Phillips screw
Use your fingernail or the flat end of a spudger to flip up the retaining flap on the SIM card ribbon cable ZIF socket.
Pull the SIM card ribbon cable out of its socket and peel it off the top of the hard drive enclosure.
Carefully peel up the two foam bumpers from the ends stuck to the bottom of the hard drive.
19 autres ont terminé cette réparation.
