Introduction
Replace the USB and Power board in your HP Mini 1000.
Ce dont vous avez besoin
With the case closed, place the Mini 1000 top-side down on a flat surface.
Push both of the battery release latches toward each other.
Remove the following two screws:
One 6 mm Phillips screw
One 4 mm Phillips screw
Use your fingernail or the flat end of a spudger to flip up the retaining flap on the SIM card ribbon cable ZIF socket.
Pull the SIM card ribbon cable out of its socket and peel it off the top of the hard drive enclosure.
Using the sharp tip of a spudger, pry and remove the four plastic screw covers from the underside of the HP Mini 1000.
The two bottom covers are short in height and are notched to prevent incorrect insertion
The upper right cover is taller in height and is notched.
The upper left cover is taller in height and is not notched.
Wedge the flat end of a spudger in between the upper case and lower case near the bottom right corner of the display.
Carefully pry and rock the spudger upwards to create a small gap between the upper case and lower case.
Continue the previously described motion along the right edge of the upper case to release the clips securing the upper case to the lower case.
Push the SD card toward the inside of the computer to unlock it from the lower case.
Pull the SD card out of the lower case.
Remove the two 2.5 mm Phillips screws securing the heat sink to the motherboard.
Carefully lift the heat sink off the face of the motherboard and de-route the curved section from next to the fan.
Before reinstalling the heat sink, be sure to apply a new layer of thermal paste to the CPU. We have a thermal paste guide that makes it easy.
Use the flat end of a spudger to lift the Bluetooth cable connector out of its socket on the motherboard.
Carefully pry the Bluetooth board off the motherboard and remove it from the Mini 1000.
Use your fingernail or the flat end of a spudger to flip up the retaining flap on the SIM card cable ZIF socket.
Pull the SIM card ribbon cable out of its socket.
