Aller au contenu principal
HP Mini 110-3131dx Screen Replacement
Ce dont vous avez besoin
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Screen Replacement, Screen: étape 2, image 1 de 3 HP Mini 110-3131dx Screen Replacement, Screen: étape 2, image 2 de 3 HP Mini 110-3131dx Screen Replacement, Screen: étape 2, image 3 de 3
    • Slightly tilt the screen downward.
    • The screen is attached by internal clips and adhesive, which means that some force will be necessary for this step.
    • Use the plastic opening tool to force the screen bezel from the screen.
    • Locate the eight silver 2.9mm screws attaching the screen to the lid.
    • Using a PH1 philips head screwdriver detach the screws.
aarondcollege
Membre depuis le 10/06/16
1 297 Réputation
10 tutoriels rédigés
Équipe
USF Tampa, Team 2-4, Cagle Fall 2016 Membre de l'équipe USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
5 membres
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 481
