Aller au contenu principal
HP Mini 110-3735dx Hard Drive Cage Replacement
Ce dont vous avez besoin
  1. HP Mini 110-3735dx Hard Drive Cage Replacement, Battery: étape 1, image 1 de 3 HP Mini 110-3735dx Hard Drive Cage Replacement, Battery: étape 1, image 2 de 3 HP Mini 110-3735dx Hard Drive Cage Replacement, Battery: étape 1, image 3 de 3
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
  2. HP Mini 110-3735dx Hard Drive Cage Replacement: étape 2, image 1 de 2 HP Mini 110-3735dx Hard Drive Cage Replacement: étape 2, image 2 de 2
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
  3. HP Mini 110-3735dx Hard Drive Cage Replacement, Backcover: étape 3, image 1 de 3 HP Mini 110-3735dx Hard Drive Cage Replacement, Backcover: étape 3, image 2 de 3 HP Mini 110-3735dx Hard Drive Cage Replacement, Backcover: étape 3, image 3 de 3
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
  4. HP Mini 110-3735dx Hard Drive Cage Replacement, Hard Drive Cage: étape 4, image 1 de 1
    • Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
  5. HP Mini 110-3735dx Hard Drive Cage Replacement: étape 5, image 1 de 3 HP Mini 110-3735dx Hard Drive Cage Replacement: étape 5, image 2 de 3 HP Mini 110-3735dx Hard Drive Cage Replacement: étape 5, image 3 de 3
    • Lift the hard drive cage by pulling the tape upward.
    • Start by pulling the tape from the side with the keyboard symbol.
  6. HP Mini 110-3735dx Hard Drive Cage Replacement: étape 6, image 1 de 2 HP Mini 110-3735dx Hard Drive Cage Replacement: étape 6, image 2 de 2
    • Unplug the cable connecting to the hard drive.
Tyrone Williams
Membre depuis le 03/10/16
905 Réputation
7 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-1, Catania Spring 2016 Membre de l'équipe UMass Dartmouth, Team 4-1, Catania Spring 2016
UMASSD-CATANIA-S16S4G1
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 270
