Introduction
The hard drive cage holds the hard drive and needs to be taken out in order to replace the hard drive. It is also important to remove it because this allows access to other parts of the laptop for replacements.
Ce dont vous avez besoin
With the bottom of the HP Mini facing up, slide both switches inward towards each other.
Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
Presque terminé !
