Introduction
If your screen is damaged, flicking, or cracked, use this guide to replace the screen.
Ce dont vous avez besoin
With the bottom of the HP Mini facing up, slide both switches inward towards each other.
Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
Remove the 8 5.0 mm screws under the keyboard using a Phillips #1 screw driver.
Un commentaire
Tengo una pregunta en pantalla habrá alguna otra que sea compatible con esta hp sin ser el mismo modelo?
