Aller au contenu principal
HP Mini 210 CMOS Battery Replacement
Ce dont vous avez besoin
  1. HP Mini 210 CMOS Battery Replacement, Battery: étape 1, image 1 de 2 HP Mini 210 CMOS Battery Replacement, Battery: étape 1, image 2 de 2
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. HP Mini 210 CMOS Battery Replacement: étape 2, image 1 de 1
    • Slide the battery out from the netbook.
  3. HP Mini 210 CMOS Battery Replacement, Disassembling HP Mini 210 Back Case: étape 3, image 1 de 1
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. HP Mini 210 CMOS Battery Replacement: étape 4, image 1 de 1
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. HP Mini 210 CMOS Battery Replacement: étape 5, image 1 de 1
    • Pull the back case off from the front edge.
  6. HP Mini 210 CMOS Battery Replacement, CMOS Battery: étape 6, image 1 de 1
    • Cut one side of the black adhesive ribbon on top of the CMOS battery with a utility blade.
    • Be careful not to scratch or damage the battery or netbook, and be sure to keep your fingers out of the way!
  7. HP Mini 210 CMOS Battery Replacement: étape 7, image 1 de 1
    • Slowly peel back the black adhesive ribbon with tweezers.
  8. HP Mini 210 CMOS Battery Replacement: étape 8, image 1 de 1
    • Pry the CMOS battery out with a plastic opening tool.
  9. HP Mini 210 CMOS Battery Replacement: étape 9, image 1 de 1
    • Pop the CMOS battery out.
    • When reinstalling, insert the battery back into the slot with the positive terminal facing up.
8 autres ont terminé cette réparation.
Heather Freed
Membre depuis le 10/06/12
723 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 9-17, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 membres
8 tutoriels rédigés
Un commentaire
after need CMOS reset. Screen is black. Is there an easy way on my HP Mini 210?
Carl Louviere - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 34
Total : 15,372
