Aller au contenu principal
HP Mini 210-1199DX Bottom Cover Replacement
Ce dont vous avez besoin
  1. HP Mini 210-1199DX Bottom Cover Replacement, Battery: étape 1, image 1 de 2 HP Mini 210-1199DX Bottom Cover Replacement, Battery: étape 1, image 2 de 2
    • Unplug the netbook.
    • Secure the netbook in a upright position.
    • Slide the plastic battery latch that secures it into the netbook.
    • Keep thumb secure on the right tab as you begin to remove the battery.
  2. HP Mini 210-1199DX Bottom Cover Replacement: étape 2, image 1 de 1
    • Remove the battery from the device.
  3. HP Mini 210-1199DX Bottom Cover Replacement, Bottom Cover: étape 3, image 1 de 1
    • Press down on the two orange buttons to release.
    • If the case does not pop off, begin to use Spudger to pry the case off the back.
  4. HP Mini 210-1199DX Bottom Cover Replacement: étape 4, image 1 de 3 HP Mini 210-1199DX Bottom Cover Replacement: étape 4, image 2 de 3 HP Mini 210-1199DX Bottom Cover Replacement: étape 4, image 3 de 3
    • Place the spudger on corners and openings in order to begin removal of the back.
    • Continue this on all corner until the case comes fully off of the back.
  5. HP Mini 210-1199DX Bottom Cover Replacement: étape 5, image 1 de 1
    • Pull the case off of the device
Phillip Winston
Membre depuis le 03/21/17
655 Réputation
6 tutoriels rédigés
Équipe
Texas Tech, Team S46-G3, Bennett Spring 2017 Membre de l'équipe Texas Tech, Team S46-G3, Bennett Spring 2017
TTU-BENNETT-S17S46G3
3 membres
6 tutoriels rédigés
Un commentaire
Awesome tip about the release buttons. Once I got it off I noted the eject latch only runs halfway down the device and the rubber feet are actually attached to the frame not the bottom cover which just has holes for them to protrude through.
I wanted to get the bottom off in order to verify the AC adapter Voltage, Amperage and Polarity (which I think ios the same for the whole 210 line.
I guess I’ll upgrade to an SSD and increase the RAM while it’s open..
Power specs for my model: HP Mini 210 1075CA: 19.5Vdc, 2.05A, with polarity being ++''inside & - -''outside .
osearth esp - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 270
