Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP Mini 210-2070NR RAM Replacement
Ce dont vous avez besoin
  1. HP Mini 210-2070NR RAM Replacement, Battery and Service Access Cover: étape 1, image 1 de 1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR RAM Replacement: étape 2, image 1 de 3 HP Mini 210-2070NR RAM Replacement: étape 2, image 2 de 3 HP Mini 210-2070NR RAM Replacement: étape 2, image 3 de 3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR RAM Replacement: étape 3, image 1 de 3 HP Mini 210-2070NR RAM Replacement: étape 3, image 2 de 3 HP Mini 210-2070NR RAM Replacement: étape 3, image 3 de 3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR RAM Replacement: étape 4, image 1 de 1
    • Orient the computer as shown in the picture.
  5. HP Mini 210-2070NR RAM Replacement, RAM: étape 5, image 1 de 1
    • Using your fingers, pull the two white clips (tabs) on both sides of the RAM away from each other. Keep pulling the clips until the RAM pops up
    • Hold the RAM on the edges only. Touching the components on the RAM might damage it.
  6. HP Mini 210-2070NR RAM Replacement: étape 6, image 1 de 1
    • Grab the edges of the module and gently lift it from the slot.
    • RAM Cards are designed with a notch on the surface to prevent incorrect insertion into the memory module slot.
2 autres ont terminé cette réparation.
Sean Kuster
Membre depuis le 10/05/12
91 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 3-23, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 90
Total : 2,419
