Aller au contenu principal
HP Mini 311 RAM Replacement
Ce dont vous avez besoin
  1. HP Mini 311 RAM Replacement, Battery: étape 1, image 1 de 3 HP Mini 311 RAM Replacement, Battery: étape 1, image 2 de 3 HP Mini 311 RAM Replacement, Battery: étape 1, image 3 de 3
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  2. HP Mini 311 RAM Replacement: étape 2, image 1 de 2 HP Mini 311 RAM Replacement: étape 2, image 2 de 2
    • Slide the battery away from the device to remove.
  3. HP Mini 311 RAM Replacement, Memory Shield: étape 3, image 1 de 1
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
  4. HP Mini 311 RAM Replacement: étape 4, image 1 de 2 HP Mini 311 RAM Replacement: étape 4, image 2 de 2
    • Lift the memory shield up and remove from the laptop.
  5. HP Mini 311 RAM Replacement, RAM: étape 5, image 1 de 3 HP Mini 311 RAM Replacement, RAM: étape 5, image 2 de 3 HP Mini 311 RAM Replacement, RAM: étape 5, image 3 de 3
    • Firmly press on the metal pins located on both sides of the RAM.
    • One side of the RAM will pop up to form a 40 degree angle with the body of the laptop.
    • Simply grab and remove the RAM from the device.
2 autres ont terminé cette réparation.
Christian Santoyo
Membre depuis le 01/31/13
495 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 20-4, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 membres
6 tutoriels rédigés
2 commentaires
4 GB modules are not supported it seems.
You may see posts in the HP Support Forum saying that the Mini 311 will accept a 4 GB module. Possibly this is true for the Pavilion DM, but not the Mini 311.
The service manual says only 2GB or 1 GB are supported.
Other people posted that they tried a 4GB module and it did not work.
rafss - Réponse
FYI, The link to buy the suggested part is wrong and not compatible.
Christine Fowler - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 17
Total : 3,680
