Aller au contenu principal
HP Mini 311 WWAN Card Replacement
Ce dont vous avez besoin
  1. HP Mini 311 WWAN Card Replacement, Battery: étape 1, image 1 de 3 HP Mini 311 WWAN Card Replacement, Battery: étape 1, image 2 de 3 HP Mini 311 WWAN Card Replacement, Battery: étape 1, image 3 de 3
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  2. HP Mini 311 WWAN Card Replacement: étape 2, image 1 de 2 HP Mini 311 WWAN Card Replacement: étape 2, image 2 de 2
    • Slide the battery away from the device to remove.
  3. HP Mini 311 WWAN Card Replacement, Memory Shield: étape 3, image 1 de 1
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
  4. HP Mini 311 WWAN Card Replacement: étape 4, image 1 de 2 HP Mini 311 WWAN Card Replacement: étape 4, image 2 de 2
    • Lift the memory shield up and remove from the laptop.
  5. HP Mini 311 WWAN Card Replacement, WWAN Card: étape 5, image 1 de 3 HP Mini 311 WWAN Card Replacement, WWAN Card: étape 5, image 2 de 3 HP Mini 311 WWAN Card Replacement, WWAN Card: étape 5, image 3 de 3
    • Begin by removing the red and blue wires from the wireless card.
    • Gently remove to avoid damaging the ends of the wires.
  6. HP Mini 311 WWAN Card Replacement: étape 6, image 1 de 1
    • Remove the two Phillips 00 3.8mm screws attached to the wireless card.
  7. HP Mini 311 WWAN Card Replacement: étape 7, image 1 de 3 HP Mini 311 WWAN Card Replacement: étape 7, image 2 de 3 HP Mini 311 WWAN Card Replacement: étape 7, image 3 de 3
    • Lift up the unattached side of the wireless card and pull out to remove.
2 autres ont terminé cette réparation.
Christian Santoyo
Membre depuis le 01/31/13
495 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 20-4, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 membres
6 tutoriels rédigés
Un commentaire
I don't have red and blue wires visible, are they tucked behind something? My pcie slot is vacant. What compatible part can i put here to increase speed and/or wireless connectivity?
Samant - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 13
Total : 1,446
