Introduction
If you are having problems with internet connection, you may want to replace your wireless network card on your HP Mini 311.
Ce dont vous avez besoin
Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
2 autres ont terminé cette réparation.
