Aller au contenu principal
HP Mobile Thin Client mt41 Optical Disc Drive Replacement
Ce dont vous avez besoin
  1. HP Mobile Thin Client mt41 Optical Disc Drive Replacement, Optical Disc Drive: étape 1, image 1 de 2 HP Mobile Thin Client mt41 Optical Disc Drive Replacement, Optical Disc Drive: étape 1, image 2 de 2
    • Turn off and unplug your laptop. Also, make sure to disconnect all the external devices.
    • After that, slide the two switches to the indicated directions in order to remove the battery and the back cover.
  2. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: étape 2, image 1 de 2 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: étape 2, image 2 de 2
    • Now you're able to remove the battery and the service cover.
    • Slide the battery upward to remove it.
  3. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: étape 3, image 1 de 3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: étape 3, image 2 de 3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: étape 3, image 3 de 3
    • Slide the service cover downward.
    • After that, lift the back cover to remove it.
  4. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: étape 4, image 1 de 3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: étape 4, image 2 de 3 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: étape 4, image 3 de 3
    • Unlock the indicated screw in order to remove the optical drive.
    • Slide the optical drive to completely remove it from the laptop.
Hassan Almunasif
Membre depuis le 02/08/18
127 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 471
