Aller au contenu principal
HP Notebook 15-ay011nr Bottom Cover Replacement
Ce dont vous avez besoin
    • Before disassembling the computer, follow these steps:
    • Shut down the computer
    • If you are unsure whether the computer is in hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect all external devices connected to the computer
    • Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer
  1. HP Notebook 15-ay011nr Bottom Cover Replacement, Removing the battery: étape 2, image 1 de 1
    • To remove the battery:
    • Position the computer upside down on a flat surface
    • Slide the battery lock latch (1)
    • Slide the battery release latch (2)
    • Remove the battery (3) from the computer
  2. HP Notebook 15-ay011nr Bottom Cover Replacement, Optical Drive: étape 3, image 1 de 1
    • To remove the optical drive:
    • Remove the Philips PM2.5x6.0 screw (1)
    • Remove the optical drive (2) by sliding it out of the optical drive bay
  3. HP Notebook 15-ay011nr Bottom Cover Replacement, Bottom Cover: étape 4, image 1 de 1
    • To remove the bottom cover:
    • Position the computer upside down the the front toward you
    • Remove the two rubber feet from the rear of the bottom of the computer (1)
    • Remove the 11 Philips PM2.5x6 screws (2) from the bottom of the computer
    • Remove the 2 Philips PM2x2 screws (3) from the optical drive bay
2 autres ont terminé cette réparation.
Alec Ringberg
Membre depuis le 08/05/18
625 Réputation
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 453
