Aller au contenu principal
HP Notebook 15-ba018ds Fan Replacement
Ce dont vous avez besoin
  1. HP Notebook 15-ba018ds Fan Replacement, Battery: étape 1, image 1 de 1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
  2. HP Notebook 15-ba018ds Fan Replacement: étape 2, image 1 de 3 HP Notebook 15-ba018ds Fan Replacement: étape 2, image 2 de 3 HP Notebook 15-ba018ds Fan Replacement: étape 2, image 3 de 3
    • Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
    • While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
  3. HP Notebook 15-ba018ds Fan Replacement, Fan: étape 3, image 1 de 2 HP Notebook 15-ba018ds Fan Replacement, Fan: étape 3, image 2 de 2
    • Unscrew the 8 screws on the back cover.
    • There are also two screws in the battery area that need to be removed.
  4. HP Notebook 15-ba018ds Fan Replacement: étape 4, image 1 de 1
    • Use an opening tool to help remove the back cover.
    • If you look at the side of the laptop, you can see where it can be separated into two parts.
  5. HP Notebook 15-ba018ds Fan Replacement: étape 5, image 1 de 2 HP Notebook 15-ba018ds Fan Replacement: étape 5, image 2 de 2
    • Remove the three Phillips head screws attached to the fan.
  6. HP Notebook 15-ba018ds Fan Replacement: étape 6, image 1 de 2 HP Notebook 15-ba018ds Fan Replacement: étape 6, image 2 de 2
    • Remove old fan and replace with a new fan.
Terrell Bradford
Membre depuis le 09/18/18
443 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 6
Total : 1,324
