Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Is the paper not coming out of your printer correctly? Consider using this guide to replace the paper feed roller in your printer.
Pièces
Aucune pièce spécifiée.
  1. Open the document feeder cover by flipping it to the left with the front panel facing you. Locate the manual paper-feed roller end of the document feeder cover.
    • Open the document feeder cover by flipping it to the left with the front panel facing you.
    • Locate the manual paper-feed roller end of the document feeder cover.
  2. Manta Precision Bit Set
    112 embouts pour toute réparation.
    Upgrade Your Toolbox
  3. Remove the 10mm screw on the side of the roller with T8 torx security  screwdriver.
    • Remove the 10mm screw on the side of the roller with T8 torx security screwdriver.
  4. Pull the side cover of the paper-feed roller to the right and remove the paper roller. Pull the side cover of the paper-feed roller to the right and remove the paper roller.
    • Pull the side cover of the paper-feed roller to the right and remove the paper roller.
Jiayin Zhu
Membre depuis le 21/10/2018
349 Réputation
3 tutoriels rédigés
Équipe
UC Davis, Team S11-G8, Lore Fall 2018 Membre de l'équipe UC Davis, Team S11-G8, Lore Fall 2018
UCD-LORE-F18S11G8
3 membres
4 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 97
